I found that after turning on the Motion Blur it was keep refresing the LV on each click.aoktar wrote:I suppose there is no different about update detections. It's expected for some complex scenes restart of LV render after first clicks. It's mostly about C4D's problems on unnecessarily dirty flag updates on some objects, ex. some effector with cloners, etc... So that's not my problem or solution is not depended to plugins. It will not restart again after a few clicks.ansarwasif wrote:after updating to version 2.25-R3, I've felt that while previewing in LV if I click anywhere it stops rendering, even while changing the Bloom the preview just restarts.
I dont' know is it just me or its suppose to be like this. its quite irritating that you wait for the render and it restarts.
Version 2.26.1 (28.11.2016) - Obsolete Stable
- ansarwasif
So please turn off the motion blur in case. It's not avoidable.ansarwasif wrote:I found that after turning on the Motion Blur it was keep refresing the LV on each click.aoktar wrote:I suppose there is no different about update detections. It's expected for some complex scenes restart of LV render after first clicks. It's mostly about C4D's problems on unnecessarily dirty flag updates on some objects, ex. some effector with cloners, etc... So that's not my problem or solution is not depended to plugins. It will not restart again after a few clicks.ansarwasif wrote:after updating to version 2.25-R3, I've felt that while previewing in LV if I click anywhere it stops rendering, even while changing the Bloom the preview just restarts.
- martincarlson
- Contact:
I have issues when I try to use Region Render. My workflow is like this
1. I have locked LV in 500x500 and select region
2. I change resolution output to 1000x1000 and expect region to follow proportionally, but instead region jumps "off" and is offseted. This region-jump is very random and behaves different every time. Does region render not work in 2.25 R3?
I have same issue in PV.
Martin Carlson, Visual and Audial Designer at Katzenwaffe Creative Studio | www.katzenwaffe.se | Soundcloud | Twitter
Intel Core i7-5930K / ASUS X99-E WS / 2 x EVGA GeForce GTX TITAN X 12GB / 32 GB RAM / Windows 10 / C4D R16 / Octane Standalone 3.03.3 / OctaneC4D 3.03.3-R1
Can you please make it so that when you select an ImageTexture node in the Node Editor, it jumps to the "Shader" tab instead of the (useless) "User Data" tab?
Also, it would be lovely if we could label the Nodes! I think both have been suggested by fuchsundvogel already.
Thanks in advance!
Thanks in advance!
Intel Xeon 12-Core @ 3.46GHz X5690 | 64GB DDR3-1333 RAM  | Nvidia GTX TITAN X 12GB
OSX 10.10 / C4D R18.041
It's not a thing which has been intentionally done. I'm not sure about a solution for that.mr_seq wrote:Can you please make it so that when you select an ImageTexture node in the Node Editor, it jumps to the "Shader" tab instead of the (useless) "User Data" tab?
Thanks in advance!
+1mr_seq wrote:Can you please make it so that when you select an ImageTexture node in the Node Editor, it jumps to the "Shader" tab instead of the (useless) "User Data" tab?
Thanks in advance!
Little things like this add a lot of wasted time.
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
						- najighassan
Hi aoktar,
i have a question, i made the update to 2.25 for C4D and since then my renders are coming out too dark.
In my preview render window everything is fine but when i send it to the picture viewer to render it out as a file it is way darker.
What could be the reason for it? Or is it a bug? Its a gamma issue i guess. But i think i made all settings correct. except i miss something.
Hope you can help.
Thanks so much
Hope you can help.
Thanks so much
- najighassan
Hi aoktar,
Hope you can help.
Thanks so much
Tommy
Hope you can help.
Thanks so much
Tommy
Hi Tommy,
what was the previous version?
could you share a simple scene that shows the effect?
ciao beppe
ciao beppe
- najighassan
