Keyframing Orthographic Scale
Lucas
Hi guys, is there any way to keyframe the Octane's Orthographic Scale?
I've tried to use a scalar node linked to it but the scale goes nuts.
I'm looking to avoid using a perspective camera with an enormous Focal Length and far away from the scene to simulate the isometric projection, but it looks like I won't be able to escape from using this workaround.
Thanks.
juanjgon
I have found a bug in the plugin. The ortho scale input is not working at all. What version of the plugin are you using? I can send to you a custom build with this bug fixed.
Lucas
Thanks Juanjo. I'm using 2.25
juanjgon
Check the attached new build. You only need to replace the plugin .p file in your current plugin folder.
LWOctane_2.2_2015.2_x64.rar
(562.55 KiB) Downloaded 145 times
Lucas
Awesome! Works perfectly!!
Thanks A LOT Juanjo!
You're the man! :D
FrankPooleFloating
Yes indeed, he IS the man. And if anyone ever doubted it, they only need look at the times of these posts... he responded in 9 minutes, and in less than an hour and half, he had a new build of the plug for this dude.... wow! :shock:
Keep rockin' J!
juanjgon
Thanks! Some bugs are easy to fix, so why wait? ;)
FrankPooleFloating
It doesn't surprise me that you are modest Juanjo. Hopefully I haven't embarrassed the hell out of you, these past three years, with my going on and on about how much you rock etc... but you are so very appreciated, by so many of us. Please know that. And I know I'm not alone when I say that after so much frustration/disappointment with various software providers (since the late 90s, in my case), that what you do is truly special. And great work (and work ethic) should be commended in the biggest way... especially nowadays. ;)
Return to “Lightwave 3D”
