noisy light
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
florian metz
hey dudes,
we are a small render team at an architectural office in munich.
we use octane with cinema 4d plugin.
we have big problems with noise in the pictures.
i attached a rendering.
its rendered with pathtracing / 9000 samples.
do you have any ideas tips to solve this noise problems?
we would be so thankful !!
flo
Hi florian metz,
it's not so easy to understand with so few infos :roll:
I'm guessing, here are some questions for you ;)
Do you have any emitter nested inside other objects?
Or maybe the noise is coming from HDR + sun?
Have you tried with multi pass active, in order to better isolate the source of the noise?
Have you tried by reducing the power value of bump or normal maps near to the glass?
How is made the glass?
Is it a specular material with particular settings?
Have you tried with the fake architectural glass option made with a dark glossy material with falloff node in opacity?
ciao beppe
RobSteady
Checklist:
- GI Clamp: 1
- Caustic Blur: 1
(- If there's still noise: Hotpixel Removal: 0,5)
Octane for 3ds Max v2.21.1 | i7-5930K | 32GB | 1 x GTX Titan Z + 2 x GTX 980 Ti
Hi RobSteady,
with GI Clamp at 1, the caustics are already gone and you can set the Caustic blur at 0 in order to not loose GPU power ;)
In general, having to reach 9000 sampling means that something is wrong (so spending some time to better understand where is the issue could be very helpful for the next project ;)
ciao beppe
RobSteady
bepeg4d wrote:with GI Clamp at 1, the caustics are already gone and you can set the Caustic blur at 0 in order to not loose GPU power
Don't see the logic; Caustic Blur @ 1 is not rendering slower for me. What are you refering to?
Also your approach seems complete overkill; just type in these values and you're good to go.
I think you can even get away with just the hotpixel removal...
Return to “Resources and Sharing”
