Changed PCs and Activation Code is not valid
julianb
Hi, I recently changed computers (although I kept my old one) and the activation key does not work any more.
The Machine ID on my new computer is. I have only bought one license for Octane and was wondering if I can use it on several machines or it will only work on my old PC.
Also if I can use it on several PCs would it be a problem if I decide to go back to my old PC and use the current Activation Key?
I just sent an e-mail to [email protected] but was not sure if I will get only an Activation code or also an answer to my questions.
Kind regards,
Julian Bransky.
Windows 7 64bit| Intel 3930K| 2x GTX 460 @700MHz 2048MB| 12GB RAM
radiance
Hi, as in my reply, no, you need one license per machine. if you reactivate the older key won't work anymore with releases as of now.
Radiance
julianb
Thank you very much for the prompt response, Radiance.
In such case I will leave things as they are- no changes need to be made. I will switch back to my old PC.
Once again- thank you.
PS. I am already kicking myself for not buying 2 more licenses when there was a discount. ;)
