Particle Instance MB causes crash
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
VFXbox
Hi there,
did anyone else notice constantly crashes with instance motion blur on particles simulations /w changing topologies?
Tested with octane alpha 3.00.04 on win10 64bit, Quadro 5000 and latest GPU Driver.
Regards, Michael
octane_instanceMB_test_v02.rar
(43.22 KiB) Downloaded 209 times
juanjgon
Yes, I can reproduce this problem here. I will try to fix it as soon as possible.
juanjgon
I have found the problem. The plugin instancing code has a bug and doesn't work with relative paths. If you use absolute paths all should work without problems.
I will fix this problem for the next build. Thanks for reporting!
VFXbox
thanks for the quick help
Return to “Bug Reports”
