Octane ROP and multiple Takes
Sub forum for feature requests etc
WhyGee
Since there is a single Octane ROP per scene, how would a multiple take workflow work? For example if I would like to render several takes at once using a ROP merge or through an external render manager such as deadline where you specify the ROP node to render (which would point to a specific take with Mantra for example).
I'd like to send out several takes to render over night but at the moment I can't get it to work. I tried some pre/post scripts but the take switch doesn't seem to happen before the Octane rop executes..
Would appreciate any suggestions you might have.
Yaniv
juanjgon
I have just found that the takes feature doesn't work in the Octane ROP node. I will fix this problem as soon as possible. Thanks for reporting this issue!
Also I want to try to remove the single Octane ROP node limitation along the 3.x dev cycle, or add a tool to render several takes using only one ROP node.
juanjgon
I think that I have fixed the problem to render any take in the Octane ROP node. Is this feature useful with your script to render the multiple takes that you need?
If you want to test it I can send to you a custom build. Please let me know your Houdini build and the OS you are using.
WhyGee
Sure I can test it. I'm on Houdini 15.0.347 windows 7 64bit.
juanjgon
This is the link to a new plugin build. It has new code to full support the "Takes" feature in the ROP node, but it must be tested. Please, let me know any problem you could find about this feature.
https://render.otoy.com/customerdownloa ... _Win64.zip
WhyGee
Hi
I haven't tried debugging but taking an existing working scene (3.00.4.0) and rendering with the new build (3.00.4.2) produces "purple" renders.
If I have time later today I will try to test on a new scene from scratch.
Yaniv
juanjgon
Weird, this build uses the same alpha 4 Octane core, and has really few changes. Please let me know if you can reproduce these problems.
WhyGee
Hi
Still haven't had time to fully debug. But I am guessing the purple is from hidden objects that aren't supposed to be rendered yet are still being loaded. I don't know if it's normal behavior but it looks like it's traversing and loading the entire scene despite nodes being hidden and not in the force objects bundle list.
As for the take issue I'm attaching a scene where I attempted unsuccessfully to create another ROP node to act as a take setter since there is only one Octane ROP allowed per scene. For some reason it doesn't render the correct frame range or Octane ROP settings (like the camera for example) for that specific take. It's a pretty big workflow limitation for houdini, having several takes in the scene, I need to render each one manually. If you have some suggestion for a way to get the batch workflow working per take, that would be excellent improvement.
Yaniv
octane_takes_test3_new_build.rar
(50.14 KiB) Downloaded 281 times
juanjgon
I am working in a new build that should support multiple Octane ROP nodes. I will post here a test build as soon as possible.
WhyGee
Perfect!
10x!
Return to “User Requests”
