Now this Juanjo already showed me in Houdini, works exactly the same
This was the flame exported as an ORBX. The imported ORBX into Standalone had Kernel 'Max Samples' = 99,999, it should have been 1,000.
Notiusweb wrote: (2) It looked like my Kernel was set to 1,000 max samples (I believe is default), but the IPR appears to be rendering past 1,000, up to 99,999. Might I need to do something with another setting?
By default the IPR is going to refine the image continuously, but if you want to stop the render after reach the kernel samples, you have an option in the plugin options panel to enable this feature. Also with this option enabled, you should get the right samples value exporting the .orbx file.Notiusweb wrote: This was the flame exported as an ORBX. The imported ORBX into Standalone had Kernel 'Max Samples' = 99,999, it should have been 1,000.
