using a png file with transparency?
Jorgensen
hi
properbly a noob question, but i'm having some problems using a png with alpha map.
i have saved an image as png, with a transparent background and loaded it as a texture, but the transparency does not work.
do i need to use a separate file containing the alpha maps for it to work?
jorgensen
WhaleHunter
Noob away...
If you want to access the alpha of a texture, you need to use an alpha image map type rather than rgb texture or greyscale texture.
Jorgensen
hi whalehunter
thanks for your feedback.
so i should be able to select an "alpha image", in the diffuse, and then select the png file with transparent background?
i have tried that, but it still wont work :-/
i know i can add a image in the opacity node, but hten i have to images i need to scale / move :-/
profbetis
Yes you need to plug in the AlphaImage map to the opacity map. Here's the trick, go back to your diffuse texture and copy the Trasform and/or UV Projection map and Paste as an INSTANCE to your new alpha texture. It will make sure they they always stay in sync if either changes.
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
Jorgensen
hi profbetis
oh man, never thought of that. thanks for the tip, you really made my day.
always nice to learn something new.
jorgensen
Return to “Autodesk 3Ds Max”
