OctaneRender™ Standalone 3.00 alpha 1
Silverwing
coilbook wrote:
Silverwing wrote:
manalokos wrote:Volumes cause light to enter inside closed spaces.
I attached an image illustrating what happens inside a closed box when a volume intercepts the surface.
Hi there. I just wanted to let you know that I am running into the same problem.
I know its being looked after. Just wanted to confirm that there is a problem with shadows!
The attachment Shadow_Problem.jpg is no longer available
nice rendering. How much slowdown do you get when you add smoke?
THAnks
I just tested it:
Without steam it rendered 2:40 Min
With steam it rendered 5:10 Min
Ray Step Lengh at 0.1
Pathtracing:<br />Diffuse Depth 5<br />Specular Depth 8<br />Coherent Ratio 0.3<br />Parallel Samples 16<br />Max Tile Samples 16<br /><br />Rendertime 2:40 min
Pathtracing:
Diffuse Depth 5
Specular Depth 8
Coherent Ratio 0.3
Parallel Samples 16
Max Tile Samples 16
Rendertime 2:40 min
Pathtracing:
Diffuse Depth 5
Specular Depth 8
Coherent Ratio 0.3
Parallel Samples 16
Max Tile Samples 16
Rendertime 2:40 min
Pathtracing:<br />Diffuse Depth 5<br />Specular Depth 8<br />Coherent Ratio 0.3<br />Parallel Samples 16<br />Max Tile Samples 16<br /><br />Rendertime 5:10 min
Pathtracing:
Diffuse Depth 5
Specular Depth 8
Coherent Ratio 0.3
Parallel Samples 16
Max Tile Samples 16
Rendertime 5:10 min
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
Notiusweb
This is strictly notes related to Speed and multi-GPU:
Standalone 3.0 alpha 1 with 12 GPU
(1) Display choppiness - I am finding with 12 GPU that the view-port display has choppiness when attempting to pan zoom or rotate, and this choppiness is there even with subsampling 4x4. In experimenting, I find that as I reduce the # of GPUs towards 1, the display linearly smooths up such that when you then pan, zoom, rotate, etc., with 1 GPU it is very smooth But, as I increase active GPUs and get closer to 12, it gets linearly increasingly choppy as I pan, zoom, and rotate. I note that the choppiness/stutter/low frame rate-ish effect occurs despite the fact that I have a dedicated card for display not used in the rendering (Titan X).
Most relevant, the linear increase in display choppiness does not occur in 2X build, in any range between 1 and 12 active GPUs, it is always smooth.
(2) Rendering slower (unless you max parallel and max tile samples), expected per developer notes
6 sec on 2.32.2
6 sec on 2.32.2
18 sec on 3.0 Alpha 1 - default
8 sec on 3.0 Alpha 1 - Max parallel samples and tile samples
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
haze
Thanks for reporting this, it appears to be a slightly different problem. Would love to see the final render once this is fixed :)
abstrax
c4d wrote:
hi admin! how to save deep animationsecqunce .exr files? Seems like the batch rendering can only save regular exr but not a deep exr??
Hi admin, I still got no answer~ would u please explain how to save animation secquence deep exr files??or should I save the deep exr file frame by frame?? :oops: :oops: Thanks!
You got your answer two days ago: viewtopic.php?p=259390#p259390
Of course, it doesn't help if you spread the same question over halve a dozen places... ;)
Elvissuperstar007
where my profile yet? How can I activate render without access to your password?
this does not work
RobSteady
abstrax, can you have a look at this scene?
Why do the renders look different? Why is the gpu usage not at 100%?
viewtopic.php?f=9&t=51898
Octane for 3ds Max v2.21.1 | i7-5930K | 32GB | 1 x GTX Titan Z + 2 x GTX 980 Ti
roeland
Elvissuperstar007 wrote:where my profile yet? How can I activate render without access to your password?
this does not work
It will ask you to reset your password. I think the old password is the same password you had in the customer area before.
After resetting your password, you can view your licenses here → https://render.otoy.com/account/octanelive.php
dafassi
Is it possible to try Blender-SmokeSims in Octane3_Alpha ?
WIN7 64bit • 32GB DDR5 RAM • Intel i7 6x4GHz • GeForce GTX780 • Blender
mib2berlin
No, the Blender developer are on it to get openVDB included in Blender but it need month to get it working maybe Blender 2.8.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
haknslash
Hi all,
I'm just now trying out the new 3.0 alpha and it seems my 3 GTX 780 Ti's fail every single time I try a project, no matter how complex or simple. I've even tried creating just a simple box, sphere, cylinder geometry test with 3DS Max. I export to OBJ format and within a minute or so, one of my cards will fail in 3.00 alpha 1 and then shortly after the rest of my cards fail. The viewport just locks up and will not move. I have no problems with the same project file(s) in 2.24.1 (standalone or 3DS Max plugin).
Any ideas?
900D | 4770k | ASUS Maximus VI Extreme | 2x RTX 2080 Ti's | 32GB RAM | AX1200i | Win 7 64bit | Autodesk Inventor | 3DS Max | Blender | Mudbox | Alias
