OTOY expands OctaneRender™ integration to NUKE, Houdini, MotionBuilder, Unreal Engine 4, and Digital Molecular Matter Engine
Forums: OTOY expands OctaneRender™ integration to NUKE, Houdini, MotionBuilder, Unreal Engine 4, and Digital Molecular Matter Engine
Re: OTOY expands OctaneRender™ integration to NUKE, Houdini, MotionBuilder, Unreal Engine 4, and Digital Molecular Matter Engine
Postby prodviz » Fri Mar 06, 2015 7:03 pm
prodviz Fri Mar 06, 2015 7:03 pm
Nice work.
Are the fluid sim options in Houdini as in depth as they are in Realflow?
prodviz
Postby juanjgon » Wed Mar 11, 2015 6:33 pm
juanjgon Wed Mar 11, 2015 6:33 pm
First test of the Houdini fur rendered with Octane. There is full support for fur UV mapping and motion blur. Also the polygonal mesh can be rendered as Octane hair for wire frame effects.
juanjgon
Postby juanjgon » Fri Mar 13, 2015 1:17 pm
juanjgon Fri Mar 13, 2015 1:17 pm
Testing the support of the Houdini primitives, nurbs o bezier surfaces rendered as tessellated meshes in Octane.
juanjgon
Postby Steven13 » Tue Jun 02, 2015 5:41 pm
Steven13 Tue Jun 02, 2015 5:41 pm
When can we actually expect the plugin for Photoshop that you announced in August 2014 and what will it be able to do/ how is it supposed to work?
Steven13
Postby 874604650 » Sat Jan 30, 2016 4:37 pm
874604650 Sat Jan 30, 2016 4:37 pm
i want buy octane render for houdini Pluing , but the octane render material entirely different from houdini material......
So that mean i need learn a lot about the material but don't have that time for now : ) specially sss
874604650
Postby juanjgon » Tue Feb 02, 2016 12:12 am
juanjgon Tue Feb 02, 2016 12:12 am
874604650 wrote:i want buy octane render for houdini Pluing , but the octane render material entirely different from houdini material......
Yes. you need to work with the Octane shader nodes, but Octane is an unbiased renderer: It has really few render parameters to configure, and the materials are really easy to understand. Take a look to the docs, and you could see that all the plugin is really easy to understand and use ;)
https://docs.otoy.com/Houdini/
juanjgon
Postby 874604650 » Wed Feb 03, 2016 2:31 am
874604650 Wed Feb 03, 2016 2:31 am
suport render vdb? or pyro
874604650
Postby juanjgon » Wed Feb 03, 2016 10:06 pm
juanjgon Wed Feb 03, 2016 10:06 pm
Yes, with the Octane 3 plugin you can render the Houdini volume primitives or OpenVDB files without problems.
https://vimeo.com/151678820
juanjgon
Postby 874604650 » Fri Feb 12, 2016 3:26 pm
874604650 Fri Feb 12, 2016 3:26 pm
Hi
recently i need to render a strawberry and water sence . So about sub-surface scattering in the material of strawberry i confuse..
i see the document about Medium nodes But i didn't get it well..
874604650
Postby juanjgon » Mon Feb 15, 2016 11:17 pm
juanjgon Mon Feb 15, 2016 11:17 pm
Yes, the scattering node can be used with some Octane materials to render the SSS effects.
juanjgon
PreviousNext
Users browsing this forum: Google [Bot] and 4 guests
Sun Mar 07, 2021 6:54 pm [ UTC ]
