Gaussian Spectrum
Forums: Gaussian Spectrum
Sub forum for help and tutorials.
Moderator: aoktar
Gaussian Spectrum
Postby DinoMuhic » Fri Jan 29, 2016 1:05 pm
DinoMuhic Fri Jan 29, 2016 1:05 pm
Has anyone a good explaination what this node does? I just can't wrap my head around it. How and when is it supposed to be used?
Can anyone link me to a throughout explaination?
Thanks a lot.
DinoMuhic
Re: Gaussian Spectrum
Postby brasco » Fri Jan 29, 2016 2:53 pm
brasco Fri Jan 29, 2016 2:53 pm
Hi Dino,
Been looking into it myself, and I think in basic terms it's a way to give you colour based on realistic spectra.
Someone please correct me if I'm wrong here.
It's best described in images and a (very badly drawn) graph :)
So inputting those values (roughly) into the GS node (wavelength in μm not nm like the graph) and putting it in the Spec channel (Index = 1) gives you this:
Increasing the width value will widen the spectra included and eventually desaturate to white.
You can of course add variation to the wavelength to give you varying colours:
cheers
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
brasco
Postby bepeg4d » Fri Jan 29, 2016 4:35 pm
bepeg4d Fri Jan 29, 2016 4:35 pm
perfect explanation, brasco ;)
In simple words we could consider it like another way to input colors. Since Octane converts the RGB colours to a spectrum, using this node, the color is not converted. It works in a similar way as the HSV space where the Hue is given by the Wavelength, the Saturation by the Width value (in the opposite direction, lower values will give more saturated colors), and finally the Value is given by the Power value. You can use it in any color input pin, for example in texture emission node gives much better results compared with a classic RGB node ;)
ciao beppe
Postby ratata » Fri Jan 29, 2016 6:31 pm
ratata Fri Jan 29, 2016 6:31 pm
Hi, can you elaborate on this
"for example in texture emission node gives much better results compared with a classic RGB node"
what do you mean by better results? accurate color? faster render?
Sandi
http://www.twitter.com/sandidolsak
6850k|64gb|4 x GTX980ti
ratata
Postby Yambo » Sat Jan 30, 2016 8:37 am
Yambo Sat Jan 30, 2016 8:37 am
wow thanks beppe! using the gaussianspectrum for colored emission is wonderful solution. i will definitely remember it.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
Yambo
Postby DinoMuhic » Sat Jan 30, 2016 6:43 pm
DinoMuhic Sat Jan 30, 2016 6:43 pm
DinoMuhic
Postby ratata » Sat Jan 30, 2016 8:01 pm
ratata Sat Jan 30, 2016 8:01 pm
Thanks for the links!
ratata
Postby MildMustard » Mon Nov 07, 2016 9:38 am
MildMustard Mon Nov 07, 2016 9:38 am
Anyone know how to find the width and power of the wavelength on a given metal, like Copper on http://refractiveindex.info/?shelf=main&book=Cu&page=Rakic/ ?
MildMustard
Return to Help / Tutorials
Sun Jul 12, 2020 8:22 pm [ UTC ]
