Render artifacts ( dots )
AlvaroLetelier
Hi guys !
I being working on different shots for a project, and this one is giving me a estrange artifacts, more like little colors spots on some areas. Any ideas ? I attach some frames.
I add Max samples and other settings to clean noise but is the same result.
Thanks guys, in advance. I hope you can give me hand. :roll:
The output size is 3048 x 1080.
Cheers.
The render settings values.
shiny little grain dots mainly in the middle.
mib2berlin
Hi, these ings are not help for dots, called fireflies.
It mostly result from 100% white and/or 100% glossy materials.
Set path term power to 1, your clamp setting is way to low, set 3-5.
There is a hotpixel remove tool in kernel settings.
The preference settings are only for defaults, make your scene settings in render kernel.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
AlvaroLetelier
Thx mib2berlin !
I will play with the settings.
Checking the materials to avoid 100 % white may help to reduce fireflies as well ?
cheers !
