https://market.yandex.ru/product/11008436?hid=91020
https://market.yandex.ru/product/10530768?hid=91020
Hi. Want to buy a new motherboard. Until I found these two models which support graphics 7 (seven x16,x8,x8,x8x,x8,x8,x8x,). Bad write on English.. if you have more options of motherboard you use write in the forum for further research before buying. Thank you
at the moment I have this ....
https://market.yandex.ru/product/730617 ... track=tabs
motherboard for optimal performance graphics cards
asrock x99 ws-e
asrock X99 WS-E/10G
asus z10pe-d8 ws
supermicro x10drx
asrock X99 WS-E/10G
asus z10pe-d8 ws
supermicro x10drx
page 2-17 for z10 pe:
quad 16 16 16 16
seven: 8 8 8 8 16 8 16
quad 16 16 16 16
x4 - x16 the scene loading .. reduce the time from starting the render button and you see the picture in the viewportvoon wrote:I wonder. What's the point of 16x for all cards? Do the cards even require that or are they able to transfer at that speed? And isn't that only important for gaming, where timing is of the essence?
whichever one of those You're going to take..just do a good research or better even write directly to those companies & ask to veryfy wheather the motherboard would work (with let's say 7 physical GPU if You are planing somethign like that), 'cos some of those motherboard might have issues..that would prevent You from flawless booting. Just a tip.
Tom is right. For dual slot gpus and 4 of them any mobo will work. With 7 or above I'd go with dual xeon having true 80 pcie lanes. There might be some extra bios settings required like 4g decoding and taking care of io space. Tutor wrote about them at his great post.
describe the work of older motherboards
ASUS M5A99X EVO R2.0
https://market.yandex.ru/product/846374 ... track=tabs = work 780+780+770 = 3GPU (x4,x8,x4)
GIGABYTE GA-990FXA-UD5
there is 4d in X99E WS if I'm not mistaking..so in theory it should work with 7GPUs as well, but..some have hard time with it..though it makes little to no sense for me as 8GPus run without issues..smicha wrote:Tom is right. For dual slot gpus and 4 of them any mobo will work. With 7 or above I'd go with dual xeon having true 80 pcie lanes. There might be some extra bios settings required like 4g decoding and taking care of io space. Tutor wrote about them at his great post.
three GPUs, Goldisart, is no problem to msot z97/z170 & other motherbords, but at msot You get a gap between two top GPUs, but then second one would touch the last one.. making layout still workable, but not ideal.. Actually for better layout You should be lookign at x99 motherboards some models like EVGA FTW & Classified would allow placing of 3 GPUs with extra gaps, but..they are somewhat short on features as been released quite a while ago..
