Feature requests
Moderator: BK
TRRazor
I'm really hoping for some HDR Light Studio implementation - at some point :)
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
Hydra
I'd like it if render settings pertinent to Cameras were associated with Cameras. Namely film characteristics, render resolution, exposure, etc. I'd also prefer if it worked in photographic parameters, not floats. So, exposure in seconds.. 1/15, etc.
Intel i7-4790K, Asus Z97-A, Corsair 32GB DDR3 1866MHz CL9, 2XAsus STRIX GTX980 DirectCU II OC 4GB, 4XSamsung 840 EVO Raid 10, Win 7 x64 Pro.
The Octane Thin Lens Camera values are stored on the DAZStudio camera. The Octane Imager values are stored with the plugin render settings. I agree that moving the Imager settings to the DAZStudio camera may be beneficial, but it is quite a difficult change, so it's something I'd rather look at in the future, once Octane 3 is complete.
linvanchene
Update / Edit:
This was included in 3.0.4.10.
Thank you so much!
Happy to finally fit all the tabs in the same activity!
:D
Please rename the OctaneRender tab to just Octane
This will save valuable space to fit another tab on the pane.
Depending on the DAZ Studio layout and style options you can only fit a limited amount of tabs on each pane.
If you use more tabs than fit the pane you end up having some tabs outside the screen and not clickable.
In this example you can see that the "Scene" tab is actually moved outside of view on the top of the pane.
Removed information about UI and Layout customization to keep this shorter.[/color]
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
Keeping feature requests succinct will mean I spend less time reading, and can push through more changes.
linvanchene
- The "help button" in the viewport, the Node Graph Editor and the OctaneRender main tab should remain activated (toggled on) when clicking on it. It is annoying that after clicking on one setting the ? mouse cursor already disappears and one has to click the help button again to read the next help text of another parameter.
The ? mouse cursor should only be deactivated when the users clicks on the help button again to deactivate it.
- Support for hair and fur was an OctaneRender version 2 feature. Look at my hair is the most used spline based hair plugin in DAZ Studio for animals. LAMH developers expressed interest in supporting OctaneRender. Was there already information exchanged between the new OcDS plugin developer and the LAMH team about lending each other assistance?
garand3d
For texture resizing would it be possible to add the option to resize all/several textures in one go? i,e the option to 'resize all textures', 'resize checked only', 'resize grey images only', something like that?
It's painful having to go through one texture at a time, especially when you have hundreds of textures loaded.
Win 10 Pro 64bit | 2 x ASUS GTX TITAN BLACK, 6GB GDDR5 | Intel Core i7 3770K, 3.50 GHz | 32 GB RAM
MSI GT83VR SLI 7RF | Win 10 Home | 32 GB RAM
DAZ Studio Pro 4.10.0.123 | OR S.A. V3.01.1b | OCDS V3.8.2.39 | GeForce Driver 398.36
I think this would take a lot of effort to implement, so would not justify the benefit. So it's not an enhance I would look to do in the near future.
This would mean you'd need to click it once to activate, then again to deactivate before you clicked a button. This may be more button clicks than the current implementation, where often you only want help on a single button.
I have progressed this issue, however I don't think it can be implemented until further down the Octane 3 release cycle, when I will have more time available.
Elele
An option to collapse the node inputs of a node, so you only see the default options for the node.
For example: for the "glossy material", if you have 3 image inputs, each with their own color correction and some other adjustments, it becomes very time consuming to find something in the glossy material node.
It would be a lot easier if everything is collasped in the glossy node and I could just click to open the bump setting for example.
Elele
Also there is an additional "my presets" list under the "used" and "emitters" lists.
It is pretty useless and what is worse, if you select a material under the normal "my presets" window, the material also gets selected automatically in the list window. Even for small scenes, that means the plugin scrolls all the way down to show your material in the lists view, which means you can no longer see the "used" material list where you need to apply your material.
Return to “DAZ Studio”
