No problem. Have funMacurt wrote:Uncia - would you mind sharing the scene files? I'd like to try what you did on my machine. Noticed you're on PC, can't help but think that speed might be a PC/Mac issue as well.
Octane vs. Arnold vs. Physical Render in C4D
So here are my renders
Octane, 2,08 using one GTX980Ti. Although the rendered image area is smaller due to demo restrictions. Arnold, 4 minutes blank. Wierd that my Octane render turned out so dark compared to the Arnold one.
MacPro 5.1, 2x3,33 6-core, 48gb ram, GTX980Ti (to run Octane), Quadro4000 (to run screens), os 10.10.5, Cinema 4D 16
- KonstantinosD
- Contact:
I'm just teasing at this point, but here's one more.. 37 sec this time..
2X Win10 PRO, Asus ROG Zenith Extreme Alpha, AMD 2990WX , 64GB ram, 2X 2080ti, all watercooled, custom loop.
- prehabitat
haha!
love it
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
- Seekerfinder
Hi Macurt,Macurt wrote:So here are my renders
Is that 2:08 mins? Octane alpha 3.2?
Tnx,
Seeker
Yes it's 2 minutes, 8 seconds. But it's Octane 2.23.2 R 6.2. Demo version.
Would love to try the 3 alpha, but it's restricted to licensed customers.
- Seekerfinder
Ok, thanks Macurt. Would be interesting to see what v3 does with that scene on only one 980TI as a comparison...Macurt wrote:Yes it's 2 minutes, 8 seconds. But it's Octane 2.23.2 R 6.2. Demo version.
Best,
Seeker
- inlifethrill
- Contact:
These tests are really irrelevant and cause more confusion than anything else. The fact that you are here means you love Octane for what it is. It is completely different from Arnold or Physical. Enjoy it, do not try to compare or turn it into something else.
Bit late to the party, and not trying to compare anything to anything, just a couple of hints that might be useful:
- You'll need to check off the "opaque" switch in the Arnold render stats on the sphere objects to have correct refractions and shadows.
- Then in Arnold most of the work is allocating the optimal number of samples when trying to reduce noise (different reasons for noise and different settings to reduce them), some useful info there https://support.solidangle.com/display/ ... ving+Noise
