OctaneRender® for ArchiCAD 3.03.3 [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
rappet
Hi Paul,
I am still getting the ArchiCAD quick quit when trying to change the midlevel parameter (in deiplacement settings)
greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
rappet
Hi Paul,
When doing a click to select for material,
then all materials are shown to select one form the list.
But the list is repeating itself about 6 times?
(this is not a v3 thing, but also previous version)
greetz,
rappet
Have not encountered anything not working properly yet with v3 (doing v2 stuff);
Did a little playing arond in v3 with displacement (tree and grass), scattering (grass), proxies (people and grass), fog and emitters.
Will get my hands on new stuff later ;-)
Cheers,
Daniel_Ward
Hi Paul,
any chance of an Alpha 3 ArchiCAD plug in update?
I've got a project that would be a good test of the polygon cap being raised! :)
Cheers, Dan.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
3.0.3.59
- Compiled with Octane 3.0 alpha 3 (3.0.3)
Daniel_Ward
Hi Paul,
the ArchiCAD 19 Version is named "ArchiCAD 19", but when I run it the installation is actually for AC17?
ArchiCAD 17 and 18 installers seem fine.
Cheers, Dan.
When I run the AC19 plugin installer it says it's the "ArchiCAD 19 Setup Wizard", and it installs into the AC19 folder - so it appears to be in order. May I suggest you re-download and try again?
There may have been an issue with the uploading of the AC19 plugin installer, so I have re-uploaded it - can you try again pls Dan?
Daniel_Ward
Hi Paul,
yes, that has resolved the Alpha 3 install for AC19 I was having.
I had understood that one of the features of the Alpha 3 release was to lift or remove the geometry cap, but I'm still getting the "the ArchiCAD model has too many vertices and can not be sent to Octane" issue on some of my large projects. Any thoughts on this?
Edit - Just to clarify, if I crop the scene back to the point that it's under the geometry cap (currently loading successfully with 3.6mil polygons) I still have 1Gb of free video ram, so it doesn't appear that the issue is related to having more geometry than can fit into VRAM.
Cheers, Dan.
Hi Dan - you can control this via the Settings parameter "Maximum Vertices/Triangles". The old Octane engine limit was 19 million triangles (this limit is removed in alpha 3).
Return to “Graphisoft ArchiCAD”
