animated texture c4d
bigipro
Hi - trying to use a simple jpg sequence in the opacity channel. Could someone walk me through that? I'm pretty new, so any help is greatly appreciated!
Use imagetexture, set sequence ranges and voila.
bigipro
Thanks! I did that - but that then I discovered that the jpg sequence had to be manually copied over to the 'tex' folder in the project. Otherwise only the first frame was getting copied.
Appreciate your help!
bigipro wrote:Thanks! I did that - but that then I discovered that the jpg sequence had to be manually copied over to the 'tex' folder in the project. Otherwise only the first frame was getting copied.
Use absolute(full path ) names so.
