Version 3.00 - Alpha10.1 (30.04.2016)
TBA3D_70 wrote:I noticed on mac, that you can´t delete a material in the node manager.
If I press the mac-delete button --> nothing happens.
If I open the material node manager new again --> all disconnected notes are gone/deleted.
Is this normal behave ?
OSX itself is not normal for me ;) Propably delete keycode is different on OSX. When don't you delete from menu commands and check?
dinf wrote:Yay, the shift of Houdini VDB is now also in C4D Alpha 3 gone :) Great, thanks!
Ahmet, do you think you'll get the cut sides also away, later on?
Sliders: confirmed. The middle position of all sliders seam to be now at 25% instead of 50%.
Slider is ok on me. Any images, scenes etc.. to show it?
Cutting of volume's edges? We don't cut any volumes. Are you sure that you correctly created and exported?
dinf
I'll do some screenshots later on.
aoktar wrote:Cutting of volume's edges? We don't cut any volumes. Are you sure that you correctly created and exported?
Same VDB is ok in standalone app and was in Alpha 2 as written some posts before. I have a closer look and come back later with stuff.
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
Dinf,
Check the slider result from LV->Help->Show Octane Nodegraph as in image. Both values should be same.
chupinsky27
I don't know if this has been addressed yet but I am finding that the time elapsed/estimate in the info bar in both the live viewer and picture viewer are wildly inaccurate. For example, I will start a render and in seconds the elapsed time will read some number of minuets. Then it seems to jump around wildly. The time estimate behaves similarly and doesn't come close to final time.
Another note, it may be a side effect of the frame buffer being out of core now, but it seems like I am getting delays/lags in sample updates in the live viewer. It seems to update the viewer in 100+ sample increments causing delays of several seconds of any update to the viewer.
I really have only tested v3 with TFD scenes so it may be specific to volume handling?
Running R16 and the latest nvidia drives as of last night (can't recall the version number).
By the way, v3 if looking very promising... excited to see the rest of announced features.
C4D R17 | c4doctane v3 beta 2.1 | 2x980ti 2x780ti watercooled | Windows10 | 64GB ram
dinf
aoktar wrote:Dinf,
A Nodegraph Scene View? Oh, wow, since when? Great!
What do I have to do to get the scene visible in the Nodegraph?
However, don't get me wrong: the values are ok. The slider positions aren't. The middle position is a 1/4 value of the biggest value. If this is 1.0, the middle position shows 0.25.
This is mostely a cosmetic thing but in some cases irritating. Have a look at the RotX and RotY sliders for an environment texture wich goes -1 from the middle to 1 on the right. Same for the phase slider wich is also a -1.0 to 1.0 slider. The only exception I found so far is the Diffuse Depth in the Kernels, wich does neither show the half (4 of 8) nor the 1/4 (2). And the RGB values behave a bit strange in connection with the color picker.
Look at the green underlined.
As said, mostly cosmetique stuff (to me).
Slider
Slider
nycjunglist
Just a heads up, for the OSX build, TurbulenceFD scenes aren't rendering. I've downloaded the demo scenes just in case anyone is wondering.
I've tried cached simulations as well as interactive sims to no avail. I've double-checked the render settings to make sure Octane was last in the list below TurbulenceFD Renderer. I also tried rendering to the Picture Viewer, but it's currently not showing any type of TFD rendering.
Ryzen 9 5950x | 128 GB RAM | 5090 + 3080Ti
Dinf,
Didn't aware this. I think that's a problem with C4D sliders. Switch back to Octane types.
David_S
OSX version renders TFD fine here. I run latest OSX version, R16, latest webdriver and Cuda driver.
But I didn't try the demoscenes.
Best regards
David
David_S wrote:OSX version renders TFD fine here. I run latest OSX version, R16, latest webdriver and Cuda driver.
Best regards
David
Ok but still having some conflicts in TFD conversion. I'll make an update soon.
Return to “Releases”
