Version 3.00 - Alpha10.1 (30.04.2016)
cfrank78
You release this version on a very sad day! Hopefully you and everybody you know is ok Ahmet! I was very sad when i heard what happened in your hometown today!
Much power to all persons that were involved and hopefully this useless killing will find an end very, very soon! :(
cfrank78 wrote:You release this version on a very sad day! Hopefully you and everybody you know is ok Ahmet! I was very sad when i heard what happened in your hometown today!
Thanks, me too.
pxlntwrk
aoktar wrote:
miohn wrote: Just a question:
Is it possible to define a certain mesh for the volume-object
instead of the default cube?
And if yes -how?
thanks!
Mike
Not yet. It's on my list.
Cool :shock:
pxlntwrk.net
TBA3D_70
Thanks for the OS X 3.0 Beta :D
TBA3D_70
I noticed on mac, that you can´t delete a material in the node manager.
If I press the mac-delete button --> nothing happens.
If I open the material node manager new again --> all disconnected notes are gone/deleted.
Is this normal behave ?
miohn
Hi Ahmet,
I notized, that the rotation slider of the environment tag behaves strange!
Maybe you can check this?
Have to go to last version because of that.
regards
Mike
dinf
Yay, the shift of Houdini VDB is now also in C4D Alpha 3 gone :) Great, thanks!
Ahmet, do you think you'll get the cut sides also away, later on?
Sliders: confirmed. The middle position of all sliders seam to be now at 25% instead of 50%.
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
tomabobu
Thank you for this new release. I'm really excite by the new baking feature.
I've made a quick test to see if I can bake blurred reflections from the camerea point of view but I'm only getting the diffuse (see attach.)
Is this feature not implemented at this time? I've tried with "Use Baking Position" enabled and the "Position" set to the camera position, but still nothing.
Cinema4D R17 / Windows 7 on Intel i7-3930K / 32 GB Ram / GTX 670 / GTX 780 / 3 x GTX 970 on Amfeltech expansion cluster
miohn wrote:Hi Ahmet,
regards
Mike
There is no change since some versions. It's fine here.
tomabobu wrote:Thank you for this new release. I'm really excite by the new baking feature.
This part is not registered yet. I'm not sure that's for your request. I'll take a look.
Return to “Releases”
