OctaneRender™ Standalone 3.00 alpha 3
Rikk The Gaijin
abstrax wrote: [*] Added support for large amounts of geometry, i.e. you can render now scenes with more than 19.6 million triangles. Please be aware though that it still needs to fit into GPU memory.
I'm gonna refer to my previous post here viewtopic.php?p=259683#p259683 in which I haven't had any reply from you guys, let's see if I get one this time.
  • I tried once more to load my 43 million polygon mesh. This time Octane didn't crash, but after 25 minutes of waiting, the rendering didn't start, and since the entire system was half-frozen, I had no choice but to kill the process in the task manager. :cry: I have a 6GB GPU, it should fit in memory, right?
  • If I try to use the Baking Camera on a mesh with displacement applied, it still renders out a black texture. :x
  • The AO Info Pass still has a sample limit of 1024. :cry:
  • The Tangent Normal Info pass still outputs a flat RGB 128,128,256 color, which makes no sense. :(
Can I have some answers?
abstrax
Did you check if you run out of system memory?
Displacement triangles are different than normal triangles and therefor not supported by the baking camera yet. Arturo is working on it, but we don't know when it will be implemented yet.
We can increase the value range of the max samples of info passes. Out of curiosity: Can you show me an image where 1024 is not enough?
The tangent normal is the normal in tangent space and is only then different to (0.5, 0.5, 1) if it is perturbed by a bump or normal map. It's meant to be used to bake normal maps.
Rikk The Gaijin
abstrax wrote: Did you check if you run out of system memory?
In the task manager, Octane was registering up to 8 GB of system memory when I killed it, but I have 32 GB, so should be ok, right?
abstrax wrote: The tangent normal is the normal in tangent space and is only then different to (0.5, 0.5, 1) if it is perturbed by a bump or normal map. It's meant to be used to bake normal maps.
Ahh, of course. I got confused because usually I bake an high-poly mesh over a low-poly one.
abstrax wrote: We can increase the value range of the max samples of info passes. Out of curiosity: Can you show me an image where 1024 is not enough?
Check the attachment.
Notiusweb
Would it be possible to throw in an export to JPEG option, it would be really nifty to not have to afterwards merge a PNG with a background image in Photoshop and then save as a JPEG if wanted.
You know, if you add a background image in the standalone (while in rendering) and save the file, it is still there the next time you open (very nifty, very handy to have this).
But not having the option to just export that out in one shot is a workflow pain.
The option would be nice...
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
mojave
If this is happening just when using the baking camera might be related to another issue with noise that we recently solved. We can take a look at it if that's the case.
Thank you.
rashadcarter
Thank you.
By system memory in this case he means Vram memory of your graphics card. Do you have enough vram to load a file with that many polygons into it? A mesh with that many polys could easily exceed 4gb, maybe even higher.
rashadcarter
There was some mention of an improved bump handling at the shadow terminator, resulting in less obvious hard edges shadows when working with bump and normals mapping. Was that new feature yet implemented? IT seems like this feature, along with round edges are really essential to making surfaces appear fully real and not low poly even though they many be. The shadow terminator is a major issue in many CG packages...easily one of he biggest CG giveaways. I'm not certain I see any progress, but I could well be missing it. Thanks for your feedback.
I love Octane. IT has made 3d fun for me again. thanks so much and please do take my money... now, with version 3. Your hard work is far from unnoticed.
cfrank78
My provider felt out for 42 minutes and i had no chance to connect to octane. I got the message: Connecting to octane live failed. It was in the standalone and in the plugin and yes of course it was activated before. i went back to 2.24.2 and everything worked.
Does this mean that from now on you have to be allways online when you wanna use octane? That would be an absolute no go for me!
abstrax
cfrank78 wrote:My provider felt out for 42 minutes and i had no chance to connect to octane. I got the message: Connecting to octane live failed. It was in the standalone and in the plugin and yes of course it was activated before. i went back to 2.24.2 and everything worked.
Only alpha and beta versions.
abstrax
Only 8GB for more than 40million triangles sounds too little, but I guess there is a bug somewhere in the geometry compilation. Could you send me the scene? Thank you.
