******* Wishlist and feedback topic ********
Sub forum for feature requests etc
zomtech wrote:Hello,
I don't know if I'm the first one to request this, but it would be nice to have some kind of drag/move function for the liveviewer. Whenever I use lock resolution, I have to either scale the liveviewer very big (which doesn't work all the time) or unlock the camera and move it to the detail I like to see in 100% resolution.
I'm sure there's a workaround for that, with camera offsets or something similar, but a liveviewer function would be best.
thanks alot,
Cornelius
I'm implementing a pan functionality for locked resolution.
zomtech
thanks alot,
Cornelius
wow, you're fast.
thanks alot! :)
Windows 10 | 1x 4090, 4x 3090 | 13900K | 128Gb
Silverwing
thanks alot,
Cornelius
This is great news. One of the things I ever wanted but somehow did not request.
Thanks for your time and effort. You´re the best!
Might I suggest a scale slider for the locked view too. So you can scale the resolution with the fixed mode. (Like in Arnold)
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
Silverwing wrote: This is great news. One of the things I ever wanted but somehow did not request.
We have much more functionality which are loaded to interface. So it's a bit harder to integrate a zoom. Remember picking dof/materials, camera manipulations, drag&drop operations, on screen info ui, etc...
Of course i'll take a look for that one day. But i don't know when....
Silverwing
Well a Zoom would not be really necessary for me.
I would love a percentage % value however.
Mathematically this just rescales the input resolution. So if you have set 1920 X 1080 px in the C4D output and lock your res in the live viewer you can set the persentage to 50% to get a 980 X 540 px output in the live viewer.
Doing this now would require me to go to the C4D output options and change the resolution.
You can save some time by the % implementation.
I hope you understand what I mean.
Cheers,
Raphael
Silverwing wrote:Well a Zoom would not be really necessary for me.
Cheers,
Raphael
Both have some hardness for me. And theorically same things.
Silverwing
I think I underestimate the process behind it!
I just thought you could just get the resolution data from C4D and add the percentage on top. So 100% is the actual resolution... and 50% is half of the res etc.
But I´m far away to understand what you have implemented there. I think as always its much harder then what I imagine.
Having the possibility to move your pic like cornelius suggested will be a great addition. Even with out my requested extras ;-)
Silverwing wrote:I think I underestimate the process behind it!
It's a custom control which has been built by ground as Node Editor. And zoom calculation is not a problem here.
DinoMuhic
Hey Aoktar,
I have many requests but I would like you to take input on 2 most important for me right now.
1) I really like the node editor since I can do so much stuff with it. However when I have a really complex node structure I need to see what is happening before it goes out into on of the material channels.
So is it possible to make a "result node" like the result node in xpresso, where you can input anything into it and it will display the result of that calculation inside the node editor? For example I have a huge node graph for making a specific texture for the bump channel, but I want to see how it looks before I input it into the bump channel. So I can put the result node in there and hook it up with the last node and it will display a 256*256px (or 2048*2048px, can be selected inside the node) flat plane (or cube, sphere, can be selected inside the node) of how the texture looks like in the moment. This would be really helpful.
The workaround I have at the moment is to make an simple object, give it a new material then input my end node of my texture into its diffuse channel and display it in the viewport. But if I could have a result node and see it directly inside the node window it would be soo much better.
2) Can we please get a blend node? Where we can blend textures into each other like in photoshop? At the moment we only have a multiply node but I often need a screen node which does the opposite. Workaround at the moment is to get 2 invert nodes -> multiply node -> invert node again to get the desired effect of a screen node.
Thank you very much for your hard work!
DinoMuhic wrote:Hey Aoktar,
Actually we have this as you can see in image. I'm waiting OSL integration for custom texture/materials.
Return to “User requests”
