OctaneRender™ for Blender 2.24.2 - 9.8 Win [OBSOLETE]
OK now I get it - all I need to do to restore the camera response for F12 rendering is set it inside Blender's Color Management. Actually, I like this approach much more than the previous one, thank you JimStar!
i7 5960X | 64GB RAM | Win10 Pro | ASUS X99 Pro mobo | Chieftec 1250W psu
MSI GTX 780 Ti OC 3GB | 2 x GIGABYTE GTX 780 OC 3GB on USB risers | MSI GTX 750 Ti for display
Blender + Octane | C4D + Corona
Flickr profile: http://www.flickr.com/photos/kubicki3d
JimStar
I found what is the problem. If you try to preview in rendered mode and check "Border", then blender crashes.
I reproduced the problem in an emprty scene too.
Can you check it please?
Thanks a lot!
Stelios
Thanks a lot!
Stelios
Win 10 | i7 3770k | 32 GB ram | 1x Gtx Titan 6 GB | 2x Gtx Titan X 12 GB
When i download the Octane server file, windows says it is damaged (there is no icon either) i have tried 3 times now.
The Octane Blender file is ok
EDIT: Ahhh, the old right click download dont work
Win 10 - 64 bit, Intel Corei7-7800X CPU @ 3.50GHZ, 32 gb ram, 2x Gigabyte RTX 2060 SUPER 8GB, OctaneRender for Blender - The most recent stable build - Houdini indie 18.5.499
When using an OpenExr for World Texture, and in preview mode, activating the render region crashes Blender.
- mib2berlin
Hi SreckoM, why do you cant use the actual plugin?
Cheers, mib
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
This version does not work with border select. No way I can work with scene so that entire window is rendering, my resolution is large. Slow... Did not even tried to work with it after that.
Version before this (2.75) is if you move camera it renders black in some camera positions. Border select work but if you rotate around object you are working with, it renders black , so I need to move camera in position in which it renders fine ... Same problem than, workaround ... Honestly for that much money I paid I really do not need to workaround basic things.
And Otoy does not want refund because I activate plugin ... imagine... I should try demo, which would probably work and does not show border select crash. So I am screwed at the end, but heck ....
I wanted to purchase C4D license too, that will not happen now.
I can not go back before version 2.75 because of other things I work with.
