Niiice belated X-Mas present, Thank you!
I just hope you didn't work through the holidays.
Btw, does this release fix the freezing viewport problem?
(it really drove me back to the 2.xxx version .. yes! I am that impatient LOL )
OctaneRender® for Poser (Windows/OSX) 3.03.3 [OBSOLETE]
Yes, 3.0.1.66 resolves this issue.Btw, does this release fix the freezing viewport problem?
Lots of feed back with this build Paul... every time I move the camera in the Poser scene, the plugin pops up with "updateCameraMonitor", set pos to -0.012356... or whatever.
RAM: 64GB
OCTANE PLUGIN VERSION: 2022.1..1.302 Prime
DAZ STUDIO VERSION: 4.21.0.5 Pro Edition (64 bit)
RAM: 64GB
Can you pls re-download and install the 3.0.1.66 release - which I just refreshed to fix this issue.every time I move the camera in the Poser scene, the plugin pops up with "updateCameraMonitor", set pos to -0.012356... or whatever.
I have refreshed the installer at the top of this thread with:
3.0.1.67
- Minor bug fixes for Render Passes and the Infochannel Kernel
3.0.1.67
I cannot reproduce this issue. Does it happen with only the Poser Primitive "Ball HiRes" for you?it seems Poser crashes when there are no figures in the scene (only props) and you try to open the viewport
just checked again an it happens with a simple cube as well as with a car prop.face_off wrote:I cannot reproduce this issue. Does it happen with only the Poser Primitive "Ball HiRes" for you?it seems Poser crashes when there are no figures in the scene (only props) and you try to open the viewport
not an issue with the version 2 plugin.
PP2014 version
Uwe
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
don't know if the event message is of any use:
if there's a figure in the scene, the plugin works fine.Name der fehlerhaften Anwendung: PoserPro.exe, Version: 10.0.5.28925, Zeitstempel: 0x54fa25ce
Name des fehlerhaften Moduls: octane.dll, Version: 3.0.0.1, Zeitstempel: 0x5678da85
Ausnahmecode: 0xc0000005
Fehleroffset: 0x00000000008ee961
ID des fehlerhaften Prozesses: 0x17b4
Startzeit der fehlerhaften Anwendung: 0x01d14412e37b64d8
Pfad der fehlerhaften Anwendung: D:\Programme\CGI\Poser\Poser Pro 2014\PoserPro.exe
Pfad des fehlerhaften Moduls: D:\Programme\CGI\Poser\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\3-64\octane.dll
Berichtskennung: 5245d8e0-b006-11e5-8403-20cf30f0dd19
Vollständiger Name des fehlerhaften Pakets:
Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
