OctaneRender™ 3.0 for LightWave™ - Alpha build 3.00.0.0
Bitboy
Trying to render the volumetrics scenes and I'm running into problems. I'm getting the same error no matter what I do when the IPR window is rendering. Another scene I've created with Octane 2.x works fine with 3.0.
EDIT: The VDB scenes work fine and also got the Dragon scene to work once - the other times it failed.
I'm using a PNY Geforce GTX 980 with 4 GB memory (680 GTX as display card), i7 6-core 3.8 GHz and 24 GB memory. Lightwave 2015.3.
Trying the logos_volumetrics.lws I get the following:
RENDER FAILURE: the render can't be completed. Enable and check the log file for more details. I've attached the complete log file as well.
Log file output where the error occurs:
00:00:04 (0004.99) | IPR: enter into the rendering loop
00:00:05 (0005.25) * OCTANE API MSG: CUDA error 719 on device 0: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
00:00:05 (0005.25) * OCTANE API MSG: -> failed to launch kernel (init4)
00:00:05 (0005.25) * OCTANE API MSG: device 0: path tracing kernel failed
00:00:05 (0005.25) |
00:00:05 (0005.25) | ++++++++++++++++++++++++++
00:00:05 (0005.25) | +++ IPR RENDER FAILURE +++ processing the failure callback
octane.log
(9.18 KiB) Downloaded 315 times
Win10 Pro 64-Bit | Geforce GTX 980 / 680 | 24 GB DDR3 RAM | i7 Hexacore 3.8 GHz
3dreamstudios
It appears 3.0 is a bit faster in some quick tests. I'm getting more samples per second with 3.0 then I was with 2.24. Maybe as much as 20% Sweet.
juanjgon
FrankPooleFloating wrote:Thanks so much Juanjo! Just have to finish a gig today.. and I will start abusing the hell out 3.0 plug.. try to find its weaknesses....
[1] Is it actually safe to have two LW installs?... No config or system conflicts if you do this?
[2] Did you find a way to kill whatever was still cooking in GPUs when IPR is closed?
You need to redirect the config files if you want to avoid problems. I will check the IPR process ASAP.
BorisGoreta
Thanks for the plugin update !
Wrong label name, instead of phase there should be ray step and so another one should be added named phase.
BorisGoreta
Here all scenes run fine except the volume instancing example, it throws RENDER FAILURE message.
juanjgon
Bitboy wrote:Trying to render the volumetrics scenes and I'm running into problems. I'm getting the same error no matter what I do when the IPR window is rendering. Another scene I've created with Octane 2.x works fine with 3.0.
Weird, Does anyone else have this problem? ... do you have your GPU overclocked or perhaps other Octane version running at the same time?
BorisGoreta
For some reason instance example and logo example stopped working ( logo was working 5 minutes ago ). I had to reload the plugin and now all examples work.
Now again first 2 scenes don't work (RENDER FAILURE), I was just loading scenes and starting IPR I didn't change anything to the scenes.
I have to clear the scene, remove Octane master plugin, exit LW, start LW, add Octane 3 plugin again and then those scenes work again.
Bitboy
juanjgon wrote: Weird, Does anyone else have this problem? ... do you have your GPU overclocked or perhaps other Octane version running at the same time?
No overclocking except maybe from the factory settings being overclocked on purpose from PNY. No other version of Octane running at all. Got one of the procedural scenes to work, 2 others failed.
Bitboy
Reloaded Lightwave and now the logo scene and the clouds scene work - they didn't before. Left over settings that didn't get cleaned out perhaps?
EDIT: instancing_volumes.lws still not working
juanjgon
Bitboy wrote:Reloaded Lightwave and now the logo scene and the clouds scene work - they didn't before. Left over settings that didn't get cleaned out perhaps?
I don't think so. Perhaps there are some issues yet with the volumetric rendering. Let's see how it works for other users.
Do you have your drivers updated?
Return to “Lightwave 3D”
