Guide: Hide Shadows - Matte Materials - Camera visibility
Forums: Guide: Hide Shadows - Matte Materials - Camera visibility
DAZ Studio (Export Script Plugin developed by Tugpsx; Integrated Plugin maintained by Paul Kinnane)
Moderator: BK
Postby linvanchene » Sat Nov 28, 2015 4:39 am
linvanchene Sat Nov 28, 2015 4:39 am
Those features are not mentioned much on the forum.
I also had to try around to remember how this works so maybe a refreshment helps others as well...
Hiding the shadows of an object
There is a Shadow Visibilty option in the parameters tab.
With that option you can select if the selected object is casting shadows or not.
In this example the Shadow Visibility on the cube is switched off.
Matte Materials
If you just want to view the shadow of an object but not the rest of the object that receives the shadow you have to use the "Diffuse" material option and select "Matte - On"
In this example a cube is casting a shadow on a plane in the daylight environment.
Because on the plane diffuse material Matte is ON the rest of the plane is actually hidden.
What you can still see in the scene is the cube and its shadow with the daylight environment background.
Matte On - selected on plane makes the plane hidden and the shadow visible.jpg
In the Environment tab switch Alpha Channel ON to hide the environment.
In this example the daylight environment background is now also hidden.
This way you can have an object cast a shadow and have the rest of the scene hidden.
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
linvanchene
Re: Tutorial: Hide Shadows & Matte Materials
Postby sixb0nes » Tue Dec 01, 2015 3:25 pm
sixb0nes Tue Dec 01, 2015 3:25 pm
Good summary. I'm going to mention "shadow catcher" so it will show up for the next person who searches for it :D
sixb0nes
Postby DrHemulen » Tue Dec 15, 2015 8:33 pm
DrHemulen Tue Dec 15, 2015 8:33 pm
Thanks, I never realized how nice the shadow thing is for lighting interiors. Now you can just put all of your meshlights outside the room :D
GTX 780, 6 gigs of VRAM - Win 7 Home Premium 64 bits
DrHemulen
Camera visibility & Visibility Control
Postby linvanchene » Mon Jun 12, 2017 11:58 am
linvanchene Mon Jun 12, 2017 11:58 am
Camera visibility
You want to see the shadow of an object cast in the scene but not see the object itself?
-> The Camera visibility will do just that.
Cube - Camera visibility On
Cube - Camera visibility Off
Note 1: Raise the object that casts the shadow a tiny bit from the ground to prevent artefacts
Note 2: The object will still cast a reflection.
Cube Reflective Plane - Camera visibility Off
-> Use a diffuse material if you do not want the hidden object visible in reflections.
Visibility control
The Visibility control lets you quickly adjust the transparency of the whole object.
Shadows and reflections will be adjusted accordingly.
Cube - Visibility Control
linvanchene
Re: Guide: Hide Shadows - Matte Materials - Camera visibility
Postby Notiusweb » Wed Oct 25, 2017 1:14 am
Notiusweb Wed Oct 25, 2017 1:14 am
Beautiful, thanks so much!
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Notiusweb
Return to DAZ Studio
Wed Jan 27, 2021 2:03 pm [ UTC ]
