hi
i have a siteplan build in sketchup, that i would like to import into 3ds max, using the fbx file format.
i have done this many times before, but this model seems to be somehow to complex or to 'heavy' :-/
it goes from 0% to 100% in 2-3 minutes - now 3ds max thinks for ever :-/
does anyone have any tips on linking between sketchup and 3ds max?
thanks
FBX from sketchup - 325mb - very slow
Forget the FBX,
Just do a straight SU to Max import.
best,
O
best,
O
WORKSTATION = Win7x64 / Intel Core i7-5930K [email protected] / 32GB ram / Liquid Cooled 4xTitanX /3dsMax 2014 / Octane Max Plug v2.16a / FARM = Intel i7-2600k 3.70GHz (x2 TitanZ) x 14
that might be, but the big advantage of fbx (and revit), is that it's easy to update via file > links > update.
not sure you can this with sketchup files?
jorgensen
jorgensen
If they are a lot of separate meshes I suggest you to attach them into single bigger ones.
It helps a lot.
M.
It helps a lot.
M.
