OctaneRender™ Standalone 3.00 alpha 1
miko3d
smicha wrote:
miko3d wrote:so its open season for explosion renders then!
What soft did you use to create the vdb?
Houdini.
uncia
smicha wrote:Try comparing PT kernel, not DL
No problem ;)
funk
I'm only testing some simple cubes right now because I'm waiting for the modo plugin.
Octane 2 uses up 10MB for some simple cubes, while the same scene in Octane 3 uses 350MB. If I set parallel samples to 16, it uses 690MB.
Is this a bug?
This is a massive difference (35 times greater mem usage than octane 2 using defaults)
mib2berlin
Hi uncia, on my system 3.0 is 15% faster as 2.24 with this scene and default settings.
01:15 vs. 00:54 Minutes
System specs in signature.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
Jolbertoquini
Hi Guys,
Excellent, so far :D I just made some test with the Volume. and I realize the light passes doesn't work here the file attach.
Sorry if still as wip just to let you know... :oops:
Best
JO
scatter_test_3.orbx
(74.96 MiB) Downloaded 314 times
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
ristoraven
Could the fog be made so that it is visible only when direct light hits it? Indirect light wouldn't do anything to the fog..
Would be great for interiors to mimic air dust particles..
uncia
Ok. Tested more real world production scenes with insane resolutions 8k - stereo fulldome...
The new frame buffer in comp memory is just God gift ! :twisted:
Forget my previous posts about Gpu memory usage in OR3. Now i see how it works.
The only side effect i have - small or Full HD resolutions. I don't have insane speed-up. I 'am experiencing some slowdowns . But i can live with that...
This new frame buffer... Omg... Just insane stuff.
uncia
mib2berlin wrote:Hi uncia, on my system 3.0 is 15% faster as 2.24 with this scene and default settings.
Cheers, mib
i will test on another machine ;)
uncia wrote:Ok. Tested more real world production scenes with insane resolutions 8k - stereo fulldome...
Maybe somethings is wrong on your setup,etc.. We are using this since weeks. I tested lot of stuff. It's faster mostly with my setups. Speed difference is different on several scenarios. Depends to many factors.
I don't have much time to give proofs. Not good idea to be hurry for judging with a few quick tests.
Always check free vram. If you see zero vram usage, this means that's working from system ram.
manalokos
I noticed that many times rendering stops updating, but updates imediately when pausing.
Also it doesn't updates sometimes when changing parameters.
