If thats true i see it as a problem that HAS to be dealt with. Because if you have someone wear a lingerie with a transparency map and
want the cloth to actually be touching the skin like its supposed to, you gonna see glowing red holes in the body through the lace...
If anyone from the moderators or the developers are reading it, I consider it a BIG bug and problem!
Weird holes in a model
My Artstation profile: https://www.artstation.com/tigersan
Software: Poser 11 Pro, Octane Studio 2020.1.5.104, Adobe Suite
My RIG:
Operating system: Windows 10 Pro 64
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
HDD: 2x WD Gold 7.68TB U2 NVME
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
I think this is a modelling/geometry issue. In real life you will not have lingerie in the same physical space as skin - the lingerie will be layered over the skin. You model should be the same....the lingerie geometry should be over the skin - not "in" the skin.If thats true i see it as a problem that HAS to be dealt with. Because if you have someone wear a lingerie with a transparency map and
No, not in the same space but really close, touching it. As it is now I have to have lingerie about a quarter inch away from the skin
and they already cause the issue so no it doesnt look natural to have lingerie floating above the skin.
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
Ray Epsilon is in meters, so if it is set to 0.0001, the lingerie vertices would need to be within 0.1mm of the skin vertices to loose the opacity look. So something is not right with your scene. Is it possible you have changed the scene scaling in the plugin settings?No, not in the same space but really close, touching it. As it is now I have to have lingerie about a quarter inch away from the skin
I haven't changed the default settings of anything i don't understand, including rayepsilon.
[EDIT] I have checked, ray epsilon affects it, but u cant set it below .00001 when i tried .000001
it automatically snapped to 0 and the problem is still there :/ hmm.
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
While ray epsilon goes down to 0, IMO you shouldn't use 0. If the default ray epsilon is not working, then I think you have a geometry problem. If you export the whole scene to ORBX and send to me, I can take a closer look.
I'm using Poser, no ORBX format, and geometry is also a commercial mesh,
morphed by me in zbrush but still its a commercial mesh by DAZ3d V4. I doubt
its a geometry issue.
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
This is the old intersect problem that Octane has. I agree it is annoying as hell and it has been reported many times without Otoy being able to fix it.
Workarounds is making sure there's no intersecting of the meshes, playing with the ray epsilon setting, scaling the scene up or remove meshes from the scene.
A nice feature would have grouping to work in the Plugin too. That way you can add stuff like clothes to the groups you want and hide them with one click meaning the objects you put in the groups are gone from the scene. This doesn't get translated to the plugin yet.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
This - unfortunately the auto-conforming doesn't work as sufficient in Poser as it does in DAZ Studio...This is the old intersect problem that Octane has. I agree it is annoying as hell and it has been reported many times without Otoy being able to fix it.
In DS you have a perfect layering of clothing on a characters body, this however doesn't fully translate to Poser, with the issues seen many times before and described in this thread...
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
If the ray epsilon does not fix the problem i usually use the morph brush to move the mesh either inward (like for hair caps) or outward so it does not intersect. That almost always fixes the problem .
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
