opacity silhouette edge object shape
Andygraph3D
is it possible make trasparent only the silhouette edge of a object ?
Unsure what you are trying to achieve here.....what object exhibits this light behavior?
gordonrobb
Not sure if you'r trying to make the edges transparent, or everything but the edges transparent. Im sure a fall-off node plugged into the opacity could do something for you though.
Andygraph3D
yes this node do it on edge object, but not on silhouette alone .. i want create a blured edge on a object silhouette
TRRazor
Didn't you ask the same question about 2 months ago?
Would you maybe have a picture of what you're trying to achieve?
viewtopic.php?f=45&t=50947
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
Andygraph3D
This is an example of what I mean, think these three objects as if they were a single object.
This needs to be done in post processing - using Nuke or Fusion. Render out the beauty pass and blur in Nuke/Fusion with the Opacity pass (in Octane 3).
Andygraph3D
With AE can do it without using octane 3 .. I wanted to know if with octane 2.x had to achieve the effect without postprocessing.
If i use falloff node are able to do something similar but unfortunately I apply transparency also at the center of the object ..
Return to “Poser”
