Passing Aperture and Focal Depth to .abc
Forums: Passing Aperture and Focal Depth to .abc
Sub forum for off topic discussion
Postby jamnique » Tue Dec 01, 2015 9:09 pm
jamnique Tue Dec 01, 2015 9:09 pm
Hi. I was hoping that since the plugin for Houdini is being developed, the developers would get the insight necessary to solve the Alembic-Aperture problem for Houdini.
Would you mind sharing how you manage to pass Aperture, Focal distance and other camera data to Octane in ABCs (or otherwise) from Houdini? I tried attaching custom Attributes to the Camera in Houdini, but I'm either using wrong names or this isn't the way to go.
The reason I'm asking is it's the only thing missing from my Houdini - Octane Standalone workflow. Sorry if this isn't the right place to ask this question.
Intel Core2Quad 9200 / 4 GB OCZ / Gainward 460 2GB
jamnique
Re: Passing Aperture and Focal Depth to .abc
Postby juanjgon » Tue Dec 01, 2015 9:33 pm
juanjgon Tue Dec 01, 2015 9:33 pm
This is something that must be supported by the Octane API, because the alembic exporter is a native function of the Octane core. This could be a feature request for Octane 3.
juanjgon
Postby jamnique » Tue Dec 01, 2015 9:48 pm
jamnique Tue Dec 01, 2015 9:48 pm
Hi Juanjo, thank you for answering so quickly. How about the Houdini's built-in Alembic ROP? Could it be made to write the camera data appropriately formated for Octane, or is it something that Octane simply isn't looking for in Alembic files?
jamnique
Postby juanjgon » Tue Dec 01, 2015 9:55 pm
juanjgon Tue Dec 01, 2015 9:55 pm
I think that even if you could add this information to the alembic file, Octane would not be able to read it. The alembic support in Octane is limited to the available parameters.
juanjgon
Postby jamnique » Tue Dec 01, 2015 10:07 pm
jamnique Tue Dec 01, 2015 10:07 pm
I see. Forget Alembic then. May I ask how you pass camera animation from Houdini to Octane? Would it be something that could be used for Standalone?
jamnique
Postby juanjgon » Tue Dec 01, 2015 10:14 pm
juanjgon Tue Dec 01, 2015 10:14 pm
You could try to export the full scene as an .orbx file, using the functions available in the ROP node:
https://docs.otoy.com/Houdini/?page_id=934
juanjgon
Postby jamnique » Tue Dec 01, 2015 10:27 pm
jamnique Tue Dec 01, 2015 10:27 pm
Thanks, but the whole reason I'm bothering with Alembic is I can't afford to buy Houdini FX, so I can't use the plugin :( Indie can export Alembic files, so I can benefit from Octane Standalone, but I can't control depth of field.
I'll try going this route (with LUA):
https://render.otoy.com/forum/viewtopic.php?f=73&t=49960
Thank you for your help. I hope this will get fixed officially in Octane 3.
jamnique
Return to Off Topic
Tue Jun 04, 2024 9:29 am [ UTC ]
