how to blend materials
gueoct
is there a way to blend different materials via a custom texture map; for example to have metallic glossy stripes on a glass surface......
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
Moonhowl
Create an Octane Mix Material.
Put your base (glass) material in slot 1 and your "coat" (metallic) material in slot 2.
Change the "Amount" value below the two material slots in the mix material to "Texture".
Put your desired alpha map texture there and voila, you'll get exactly what you are after.
Asus V Extreme motherboard, i7-5930K CPU, 32 GB DDR4 Quad Channel RAM, 3x Nvidia Geforce 1080ti, Windows 7 Ultimate 64, 3DS Max 2019 64
gueoct
Of course, that was it!
Thanks a lot!
Return to “Autodesk 3Ds Max”
