OctaneRender™ for Blender 2.24.2 - 9.7 OSX [OBSOLETE]
Locked
JimStar
The OSX version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Merged with most recent Blender 2.76b version.
  • Fixed the bug: internal motion blur render kept failing if the blurred object existed not in all frames participating in blur calculation.
  • Minor fixes and improvements...
Installation:
- Just run autoinstaller file.
DOWNLOAD
Blender Octane Edition - v9.7 OSX (82.5MB autoinstaller file)
DEMO is available..
Blender Octane Edition DEMO - v9.7 OSX (81.7MB autoinstaller file)
For network slave and daemon please download standalone installer here:
viewtopic.php?f=24&t=50498
Please, if you decided to report a bug:
- Don't post here the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
- If you like to discuss something about the plugin - create a separate thread, don't flood in these testing threads please.
Any meaningless or rebus-like "reports" here will be deleted, just to keep the testing threads clean - because these threads are directly used as the source for fixing and improving the plugin.
pegot
I'm still having an issue where my background environment is rendering incorrectly when layer passes are used as reported here from the previous version:
viewtopic.php?f=32&t=50712#p255011
This is kind of annoying as it means I need to run two seperate renders from Blender instead of just having both passes output to a single multilayered exr.
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
pegot
I have not been able to get Blender Mask Layers to work. I am following the steps as outlined in the below video but the foreground object is not masking the background object - both appear in the final render. Works fine in Cycles, though.
https://www.youtube.com/watch?v=xbdfpo4dOyk
Is this feature supported in Octane Blender? Please advise.
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
grimm
I'm not sure that is supported yet? I don't know if it would work for what you are doing, but you can use the matte option. I wasn't able to figure out how to not have a shadow cast by the matte object.
pegot
Hadn't though of the Matt material. Octane ID Render Layers also work for this by the way... but that limits you to rendering each layer separately. I would not know how to excluded the shadows from those either.
The nice thing about Blender layers is that each pass can be exported into a single multilayer EXR file or output to separate files using a node set up. For what I needed Octane Render layers worked fine. One thing I do not completely understand about Octane ID Render Layers though is why anything beyond the first layer can't be assigned a global mesh type?
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
JimStar
Next version HERE.
Locked
Return to “Releases”
