Missing Materials after reopening project
adriendupagne
Hi
So I had applied materials from otoy library and even set them to offline but when I closed the project and reopend it the materials were missing.
Anyone know why its doing this?
What you mean exactly? Materials are unvisible in livedb manager or in scene? Or do you mean textures not materials?
adriendupagne
They appear to be fine but when you render in live viewer etc the texture/material is gone. The texture/material icon is still applied to the object but if you click on it you can see the material isn't actually present. No texture, just a diffuse colour.
adriendupagne wrote:They appear to be fine but when you render in live viewer etc the texture/material is gone. The texture/material icon is still applied to the object but if you click on it you can see the material isn't actually present. No texture, just a diffuse colour.
It should work fine as usually. A few screen shots are better than thousands words i suppose. I couldn't understood well. What do you see when you check the image textures?
