Version 2.24.2-TEST6 - Test only
Equinoz
X-particles still can't use in TEST 4 version O_O
only display one sphere (using object tag)
Equinoz wrote:X-particles still can't use in TEST 4 version O_O
I can. What's your xp?
dinf
aoktar wrote:I'm updating to a new version. Please let me know any issues or experiences. Thanks.
Thanks alot!
FYI: Like in Test 3, same one of my PCs can't recognize the R17.dll. And again, R16 is working.
Btw., XP , did you describe the Particle Rendering tab somewhere?
| Win 10 | 64 GB RAM | AMD 5900X | RTX 3080 12 GB| C4D 21| C4Doctane v2022.1.1|
Thanks alot!
what about version number and plugins? Any message in console?
if you put object tag to a supported object, you'll see that. Btw, i'll add a few sample scenes to check it.
dinf
aoktar wrote:what about version number and plugins? Any message in console?
No console message about Octane. It is like this C4D can't see it. As told: when R16 and R17.dll are in the plugin folder, C4D starts also as if the R17.dll wasn't there, without double dll error or console messages except Octane is loaded. Tried it for testing purposes once.
Same C4D installation and Plugins like second PC wich is working well with R17.dll. Shall I share a list of the installed plugins?
Both Win 7 Pro with C4D R17.032. I'm sorry, I don't have more infos on that and don't know how to get more.
Thanks again!
Elprezzy
xparticlemotionblurissue.zip
(90.81 KiB) Downloaded 191 times
Not sure if im being a noob idiot but I can only get sphere particle motion blur rather than from the object particle.
r15 broadcast xp3
craig
r15 broadcast xp3
craig
Somethings is wrong here. You need to select full motion blur in render settings.
I have added new sample scenes for Scatter and X-Particles. You can find in first page.
Also particle engine is still not complete and motion blur is missing for some situations. As i wrote before i'll improve and update with 3.0's progress.
Gumz
Great! Thanks for another fine update :)
Gumz wrote:Great! Thanks for another fine update :)
Thanks. I found that i forget to remove some debug output from hair engine. So i'm uploading a fixed version as 4.1. Appologies for this.
eyeonestudio
Can't Render : Close Spline...
I hope to accomplish in the next version. ;)
C4D R2025 / Win11 / AMD TR WX Series / 256Gb RAM / RTX3090 / 100GbE
Return to “Releases”
