Slave Rendeing fails Only during Batch Rendering
Moderator: JimStar
p3taoctane
No slave rendering input while batch rendering an animation.
I am able to render from Standalone and Maya using the RenderView Window and slave rendering will engage and help in the render.
In batch rendering the slaves do not engage at all. Is there any think that needs to be checked in the Octane Settings that might be causing this to happen.
All systems have same versions ... I guess you know that or the still render would not engage either.
The Two systems are both running Windows Professional 64 Bit
In the Network settings tab in Octane It shows them as running.
p3taoctane
Anything Jimstar?
JimStar
p3taoctane
Thank you
Is there a way to run this saved maya file from Mac OSX
Right clicking on Mac OSX does not give you the render option.
Return to “Autodesk Maya”
