Beeple Gobo01 - Project files
tomabobu
I'm trying to open the Gobo01 project that Beeple is sharing on his site but I'm getting a "Incorrect File Structure" error.
Can someone else try to open his project to see if he gets the same error?
I've tried with R17 and R16 but no luck.
The link from his site is:
http://www.mediafire.com/download/m60dp ... OBO-v1.zip
You can find the sources to all of his projects here:
http://beeple-crap.com/resources.php
If you haven't studied his scene files till now, you are missing on some great study material regarding Octane and Cinema4d.
Best,
Bogdan
Cinema4D R17 / Windows 7 on Intel i7-3930K / 32 GB Ram / GTX 670 / GTX 780 / 3 x GTX 970 on Amfeltech expansion cluster
Ibycus
Worked for me just missing a bunch of plugins that he uses. Otherwise opened like normal.
tomabobu
Are you a Mac user? Cause I've tried at work on a Mac and everything was Ok, but on my Windows at home it wasn't.
I've only used 7zip and WinRar to unzip the archive, with the same problematic outcome, so I will try other alternatives.
tomabobu
I've found it wasn't a corrupted scene but an error from X-particles plugin.
Yambo
im also getting "Incorrect File Structure".
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
tomabobu
Remove the Xparticle plugin from the Cinema4d install directory because Beeple uses 3.0 and I think you have a 2.0 version that is generating the error.
Yambo
Works! Thanks.
https://yambo.me
