Version 2.24.2-TEST6 - Test only
pxlntwrk
laubwerk will be great !! :D
i cant touch random rotation and scale ( all assets react same way) with scatter. Normal ?
pxlntwrk.net
pxlntwrk wrote:Hi,
Check uniform scale and rotate works only for H axis atm. Gui needs some polish.
pxlntwrk
thanks !
will check that tonight
pxlntwrk.net
useruser
first test with 2 hairobjects in liveviewer: :D
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
Gumz
Finally had time to play with this. Working now!
Impressive release! Scatter is mind-blowingly fast even with an insane object count.
Love it love it love it!
pxlntwrk
it's working :D
pxlntwrk.net
Nuge
aoktar wrote:
Nuge wrote:Ahmet,
Firstly you have and continue to do an amazing job, keep up the good work!!
I do mainly arch viz renders and import the models from Archicad, problem is that i cannot control how the meshes are generated on the import process and i end up with meshes with varing sized polygons as per the attached file, this has not been too much of an issue until i want to cover the mesh with a grass object. I have tried various methods (Cloner,Carbon Scatter, Multicloner) but they all seem to use the polygon (centre/face/surface) to calculate the position.
I have just tried your scatter object and have run into the same problem, is there some way to distribute the objects in a more uniform manner without using the polygon data.
Regards Nuge
Thanks for words! About your issue, Scatter is actually capable to do what you want. But i suppose it's not working well on Test2 due lot of playing with codes. Here is a result for you.
I think i love you!!!!
The "Keep Away" value solves the issue
Keep up the good work
Nuge
C4D R19 / Win 10 / 7 GTX 1080
eyeonestudio
X-Particles (3.x) With Octane Material Not Working..... (Yes~ This is Test Version) :shock:
CINEMA 4D R2025
Win11 / AMD 7995WX, 3995WX, 3990X, Intel 10980XE / 256Gb RAM / RTX4090, RTX3090 / 100GbE, 40GbE, 10GbE
Nuge
I'm trying to do better without using "Keep away". Maybe for TEST3. Thanks!
eyeonestudio wrote:X-Particles (3.x) With Octane Material Not Working..... (Yes~ This is Test Version) :shock:
Yes it's still WIP. This mean nothing yet finished and will be in improvement for a loooong time. But you can assign materials to any object and drop to objects list in Objet Tag.
Return to “Releases”
