Can the Octane plug in for DAZ 2.0 render equitrectangular?
Moderator: BK
- LuvMultimedia
- Contact:
Hi -- I use DAZ studio and wondered how to render stereoscopic equirectanular using the octane plug in?
WIN 10 64 | Geforce 970| 16 GB
currently the panoramic camera node is not supported by the plugin yet, but you can export your scene already set up in DAZ to the Standalone and do the render there only changing the camera parameter
ciao beppe
ciao beppe
- larsmidnatt
this is what I had to do. Although I have not used standalone in years, it wasn't too hard to simply find where the camera setting was and adjust. Just remember to start the render in daz with the plugin before you try to export. Otherwise the exported file is empty.bepeg4d wrote:Hi,
ciao beppe
Win10 x64
i9 10900k 64GB
2080S 8GB
DS 4.15 OcDS Prime ^_^
i9 10900k 64GB
2080S 8GB
- LuvMultimedia
- Contact:
Hi, Thanks you--I am currently experiencing trouble. I build the scene, pull it to the stand alone but when I try to pull the alembic file in it either crashes, freezes, or says "cannot import alembic" basically...is there tutorial on this process? Thanks in advance for your help...larsmidnatt wrote:this is what I had to do. Although I have not used standalone in years, it wasn't too hard to simply find where the camera setting was and adjust. Just remember to start the render in daz with the plugin before you try to export. Otherwise the exported file is empty.bepeg4d wrote:Hi,
ciao beppe
- LuvMultimedia
- Contact:
bepeg4d wrote:Hi,
ciao beppe
Hey I saw your other response--thank you for the reply. I am getting frustrated still because the alembic file won't pull into the standalone scene...not sure what to do...
