Was just wondering if anyone has run across this...
I'm trying to render some Realflow animations and when I render with F9 or with IPR my scene renders fine, but when I hit f10 it just renders a black screen (blank) anyone run into this? The Lightwave objects will render fine, but the RF liquids won't render at all.
thanks,
bruce
f10 Realflow objects not rendering
It is really strange that a scene that can be rendered without problems with F9 doesn't render with F10 ... if you want to send me the scene, and a link to download the realflow render kit that you are using, I could test it here.
just wanted to update this post having found a solution:
The solution was to make sure in the Render Target main Node that the project was set to "reload scene files" instead of "update". This enabled Octane to load the information from Realflow for each frame.
Thanks juanjgon!
bruce
Thanks juanjgon!
bruce
