OctaneRender® for 3ds max® v2.23.2 - 2.8 [OBSOLETE]
Goldisart
either default to enter in the direct - all glass fake shadow ;)
still in the direct rendering of the passage through the glass are all doing fakie shadow
but I don't insist on it - I'm just saying what I encountered when converting
oguzbir - the script :) I know how to run
And one more thing.... Not quite correct is the conversion of the Vray materials . It would be nice if someone started a conversion and thus it was possible to work with large libraries of 3D models already created for Vray
oguzbir
Bug report (sort of)
After a render is closed or ended in given max samples.
Even when using octane viewport and Octane viewport is closed.
GPU's tend to continue allocating the memory that processes during render,
even when the Octane Viewport or Max Render is closed or ended.
To end the memory allocation you have to deselect gpu devices and hit apply.
FYI
See attached image
My Portfolio
coilbook
oguzbir wrote:Bug report (sort of)
FYI
See attached image
same here. I have to restart computer to drop gpu clocks
Goldisart
I would like to see the function of light distribution in the light sources
control of the light distribution is only in black body material - why would this feature not be included at least in IES
darkline
2 more problems :
a)Motion blur duration value appears to have no affect on the motion blur.
b) 'receive shadows' has no effect - at least on the matte objects I'm using.
I need the matte objects in my scene to obscure objects and shape the bounce light onto my render. But I need the matte objects to be shadow free.
This is essential for creating render passes - please can you take a look and fix?
thanks
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
3dgeeks
darkline wrote:a)Motion blur duration value appears to have no affect on the motion blur.
You need to advance the play head one frame for the effect to take hold. An Octane anomaly.
Elvissuperstar007
why there is no integration of these functions?
gradient is useless
JimStar
Next version HERE.
Locked
Return to “Releases”
