Version 2.24.1-R3 (06.10.2015) - obsolete stable
momade wrote:Yes I also save incremental numbers and the dublicated materials are also the ones in the beginning of the material list. i will observe this further.
Please. I can't find it by this way. Someone should describe better what causes this.
momade
still could not find out when it happens exactly. when i see them, they where already duplicated. i will keep an eye on this though.
aqcoelho
I Think is something about the new mix material support on COPY/PASTE
If i duplicate an object with mix material, holding ctrl+drag works fine, but if I copy the object with mix material and paste in same scene, it duplicates only the mix material.
ALIENWARE | Win 7 64 | 2x Geforce GTX880 8GB | i7 | 32GB |
aqcoelho wrote:I Think is something about the new mix material support on COPY/PASTE
Can you capture a video to show it? I can't see anything is wrong here.
momade
could it be that it occures on scenes, that where created in 2.24.0 and went on being edited in 2.24.1?
i have observed very strange behaviours on scenes that "walk trough" octane versions...
momade wrote: i have observed very strange behaviours on scenes that "walk trough" octane versions...
Can you explain better?
I found it. It happens on copy/paste to same scene. I'll check it.
aqcoelho
Sorry, no video capture, buti did a screen shot,
If I just drag the object holding Ctrl to duplicate, works fine and dont duplicate the mix mat
momade
also i observed closely, that when i ctrl-drag any material-tag onto any othe object. the mix material dublicates in material manager.
momade wrote:also i observed closely, that when i ctrl-drag any material-tag onto any othe object. the mix material dublicates in material manager.
I can't reproduce here. Can i see somethings to illustrate better?
Return to “Releases”
