Version 2.24.1-R3 (06.10.2015) - obsolete stable
desire wrote:Hi, aoktar!
May I ask you about masks? Do you plan to improve masks' accuracy?
Because the one-pixel-gap between objects and shadows is quite visible even at huge resolution renders when i use render layer feature, unfortunately.
And object ID masks are not precise too... (correct me if I'm wrong)
Thank you.
It's not related with plugins. Completely a renderer issue. I'm not sure it can be improved.
momade
hello aoktar.
sometimes when i solo things, the 'LiveViewer' continues to show the soloed objects. but sometimes solo objects vanish from 'LiveViewer'... any idea what i have to look out for?
momade wrote:hello aoktar.
try to click to anywhere again. Propably update message is ignored due update in progress or so. Nothing to do for current version.
momade
ok i will try. i always hit resend scene and nothing happend maybe clicking somewhere will do the job. thanks for the quick answer.
momade
an other thing im wondering.
can an emissive diffuse material emmit to both sides of the surface?
momade wrote:an other thing im wondering.
No, it's a natural behaviour of Octane.
momade
ok.
im now checking the great 'octane texture manager'. see the attached image.
there seem to be some missing textures in my materials, but i double checked all slots and nothing is missing. the emodel is rendering fine. in fact, the images that are referred to dont even make sense.
any hints?
also rightclicking and hitting remove, doesnt remove these slots.
Augustronic
momade wrote:ok.
any hints?
Open all materials in the node editor and search for orphaned texture nodes.
Have a nice day!
Achim
Aixsponza
momade
Augustronic wrote:
momade wrote:ok.
any hints?
Thank you Augustronic! i'll try that.
eightvfx
hello Aoktar !
thanks for all the work you are doing !
to continue on what was saying desire : " Hi, aoktar! May I ask you about masks? Do you plan to improve masks' accuracy? "
when you say it's not pluggin related... do you think in release 3 > it s something that will be improved ?
thanks.
PS> about this release 3... any date in view ? ;))
thanks again!
Return to “Releases”
