Also, I'm working on a new mode, DECORATION-scatter!
This mode is specifically designed to make it easy to place manmade objects around like chairs, interior objects, etc.
I will provide gizmos that allow placement, rotation and scaling. Per different object, you can set a reference width and height so you have a better idea about it's placement.
It will be easy to add many different types of objects, so you don't even have to name them. You can just keep them apart by their type number. It will work on a per-project basis.
And then it will just export a different *.CSV file for each object type you placed around. Easy.
Phantom Scatter [1.12.2] Export and press CTRL+V in Octane!
- Phantom107
Developer of tools for Octane:
Phantom Scatter - Phantom Node Link - Phantom Photo Match - Phantom Architecture
- Phantom107
Another new feature in 1.9 is the ability to re-order the UI modules on the bottom to fit your personal preference:
Just enable EDIT MODULES, move them around as you wish, and then disable EDIT MODULES. That way you won't have the re-arrangement buttons in your way while using the software.
- Phantom107
Apparently a user has problems with Avira. Does anybody know a fix for Avira to not call a false positive on Phantom Scatter's DRM?
- Phantom107
Phantom Scatter 1.9 dev pic, image shows the upcoming DECORATION-scatter, excellent for placing around misc objects.
- Phantom107
There was a problem with the contact form on the site... please re-send if you submitted in the last 24 hrs.
- Elvissuperstar007
- Contact:
This plugin works generation of particles falling from the roof and pipes? and whether you can change the size and density of water distributions?
http://www.youtube.com/watch?v=HvT8HPCh-5E
https://vimeo.com/14240318
- Phantom107
It doesn't at the moment, but I gotta say that looks very cool. I hadn't thought of that.
I'll be definately looking into this!
- Elvissuperstar007
- Contact:
Mouse does not work, do not know how to scroll the scene
It may be necessary to add control octane render
- Phantom107
While holding the right mouse button, you can use the mouse to look around or use WASD/QE.
I'll make that more clear in the next version of the manual. Currently working on Phantom Scatter 1.9.
- Phantom107
Phantom Scatter 1.9 picture of the new DECORATION-scatter tools.
You can place up to 60 different types, where each type is basically an object type like a table, chair, car, whatever you want. You can give each type a name and reference bounding box. Grouping is supported aswell
This going to make placing stuff around in and around buildings a LOT easier and faster.
