Weird Bug with Image Maps/C4D Directory Prefs
RyanJP
I downloaded a scene file from an artist and was dissecting it, was pulling my hair out trying to recreate the effect of a glossy material where the main texture was created by an image in the roughness channel. No matter what image I loaded from my usual textures folder (not the C4D default tex folder) I was not getting any results, like it would go from nice to completely flat. Yet whenever I loaded the projects' included image file the results were immaculate. I thought maybe because the file was black and white? Maybe it was a tiff and mine was a jpg? I went down this troubleshooting rabbit hole for a while before I finally tracked it down to this weird inconsistency- the images I was trying to load were all located within folders I had specified in my C4D preferences as "Texture Paths". I deleted all these folder paths and restarted Cinema. All the same files worked fine. Then I investigated further- seeing if it made a difference how I responded to the C4D prompt to "copy texture to project folder" or whatever it always asks you, no matter whether I chose yes or no, the texture would work, but if C4D never had to ask (bc of pref settings) it wouldn't work. :|
Windows 10, GTX 980, 32GB RAM... some other stuff
I couldn't figure well your issue. It should work as C4D's default image handling. We use same procedures and same search paths anymore. Which version are you using?
