IES files
Have I confused myself successfully? I was under the impression, Octane can load .ies files as image texture to create IES emission lights? Or did I dream that up? The open file dialog for an image texture node in blender octane does not list the .ies files, though.
- mib2berlin
Hi voon, nice to see you again.
You need a Floating image connected to Distribution.
I don´t really understand how the Transform work but work, kind of.
Cheers, mib
Cheers, mib
- ies_test_simple.blend
- (88.44 KiB) Downloaded 353 times
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
- mib2berlin
Oh, this is an old test file, will check to create a new with latest BfO.
Cheers, mib
Cheers, mib
- mib2berlin
OK, you have to disable "Filter" in file browser to see the IES files.
The symbol looks like a funnel.
Cheers, mib
Cheers, mib
- regionfive
- Contact:
Hi voon,
does it really work for you? I had issues all the way since Version 2.
I figured out that you had to put a xyz projection node to Projection and play with the ies texture´s gamma to get to an "ok" result.
But I still don´t really get the result i want. IES are handled different since v1.5
regards
regards
