Version 2.24.1-R3 (06.10.2015) - obsolete stable
Hi Mikla,
is it possible to check your scene? I have no idea about content and hard to see problem. Which version are you trying?
I'm trying to add some controls to detect possible crashes and limitations. But would be nice to see some scenes with issues.
Mikla
aoktar wrote:Hi Mikla,
I'll send the scene file if i can find the exact steps to replicate the problem. Thanks!
chupinsky27
As reported by another user posted on the last page, I am having a similar, if not the same issue regarding a lag or disconnect of the update of the LV and C4D's viewport. I have my workspace set up pretty normal... default workspace, LV on left, C4D viewport on right. If I navigate an octane camera in C4D's viewport, there will be a big delay in when the LV picks up the change in camera positioning. Yet, If I navigate in the LV, I do not have such a problem and both LV and C4D's viewport sync up perfectly. I have a pretty simple scene, not a ton of geo, one material.
-Craig
C4D R17 | c4doctane v3 beta 2.1 | 2x980ti 2x780ti watercooled | Windows10 | 64GB ram
chupinsky27 wrote:As reported by another user posted on the last page, I am having a similar, if not the same issue regarding a lag or disconnect of the update of the LV and C4D's viewport. I have my workspace set up pretty normal... default workspace, LV on left, C4D viewport on right. If I navigate an octane camera in C4D's viewport, there will be a big delay in when the LV picks up the change in camera positioning. Yet, If I navigate in the LV, I do not have such a problem and both LV and C4D's viewport sync up perfectly. I have a pretty simple scene, not a ton of geo, one material.
-Craig
Is it possible to capture a video to show it? Thanks.
momade
hello aoktar.
i dont seem to get an animated texture working anymore. i have a jpg sequence in a sub folder of the text folder. i load it as an image texture into the material diffuse slot. and a soon as i set the movie end frame to anything but 0 the material turns grey.
any hints, what im might be missing?
momade
momade wrote:hello aoktar.
only i i load the image sequence as a normal "c4d-load-image" it works. only within the "image texture" i seems broken.
Can you show image names and your usage?
momade
they are named like this: and the tex subfolder is: tex\good_bad\bad
Momade,
can you try this?
1.rar
(358.47 KiB) Downloaded 225 times
momade
aoktar wrote:Momade,
can you try this?
its working here, but i dont get it:
your image sequence gos from "test_00050.jpg" to "test_00059.jpg"
yet, you set your movie start to 50 and your movie end to 100.
how do i make my own image sequence work?
Return to “Releases”
