I can´t get any camera motion blur. I must be doing something wrong. Can someone explain how to enable it and change shutter speed please. I tried enable it in render meny and set it to subframe with setting 0,3 and 6 samples. The objects that moves (mavable proxy) gets blurred but not the camera.
On other scenes where i have no moving object aand only moving camera what should i do to get camera motion blur? Can animation camera only be enabled? Should camera be set to movable proxy or what?
Camera motion blur
- Synthercat
+1 Is there no camera blur?
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
- Synthercat
Hey?!? I just solved this!!!
First I render all the frames without composition
then I change the renderer to blender internal so I can activate vector on render passes and then I can add a nice vector blur node to the compositor after the image frames node I previously made as input!
Works like a charm!
PS : The developers could leave the "Vector" on render passes I guess so that this would work without the whole extra step
Works like a charm!
