Octane Render for Modo Batch Render
v1adut
Hi Paul,
is it possible that we will have an octane render batch render plugin that will read a list of scenes that we set partameters and we let the software run overnight.
There is a plugin for modo http://community.thefoundry.co.uk/discu ... =4&t=48440 can we have a clone for octane render.
Cheers,
Vlad
Hi - that script looks like it only supports up to Modo701. The next release of the plugin should hopefully have a new command added - to save the current render to file. So in theory, it will be possible to write a simple python script to check if the render is complete - and if it is, save to png and load the next file in sequence.
v1adut
face_off wrote:Hi - that script looks like it only supports up to Modo701. The next release of the plugin should hopefully have a new command added - to save the current render to file. So in theory, it will be possible to write a simple python script to check if the render is complete - and if it is, save to png and load the next file in sequence.
I feel you are busy with all the plugins you support today for octane Paul, but if you can close this functionality this will be a nice addition for over night render for the files I made during the day.
Cheers
Vlad.
LFedit
This would be amazing. Not saying its you or anything but I think more devs need to look at maxwell render. Their multilight interface and network render interface are amazing. Let alone the referenced material system. Like I said, you do a great job and I love octane, especially the speed. But just those "little" things (I'm sure they aren't so little) would really make it the ultimate render.
Win 10, Threadripper Pro, Dual 3090s
Return to “Foundry Modo”
