Octane info stats showing up in rendered frames
CCIDgfx
I'm having an issue where the Octane render status bar is showing up in my rendered frames. What is causing this and how can I fix it?
Thank You
3D Motion Graphics Designer
Intel i9 13900K / 128gb DDR5 / 1 Nvidia 5090 FE / PSU EVGA 1600w / WIN 11
Is it from picture viewer?
CCIDgfx
Yes...every 3rd frame or so.
It should disappear when frame finished or cancelled.
CCIDgfx
I was rendering a 250 frame animation. When I was compositing in AE is when I noticed it flickering through the frames. I re-rendered the sequence with no issue. But that was an hour on a deadline I wasn't counting on. What else could cause that?
Maybe an object/tag of other plugin caused to break frame rendering or any cuda error. Hard to estimate without testing.
CCIDgfx
No other plugins or object tags being used. Only 2 Octane lights and an environment. It was a pretty simple scene. No motion and only a couple MoText objects. I can upload the c4d file if it will help.
GSP Intro1.zip
(60.48 KiB) Downloaded 193 times
I'll test it when i'm free. But can't be possible to generate same results. What was your plugin version and os?
Thanks.
CCIDgfx
Thank You
