I can't figure out why.
No. This does not work. That setting is what causes the problem.aoktar wrote:Answer is simple for people who don't understand fundamentals of plugin and Renderer's workflow.
1-Set render method: "resend only updated". It's default on last versions.
Why should I know what a state machine is, let alone that Octane is one? Your problem, which is the same with a lot of engineers, is assuming the end user has the same amount of technical comprehension as you do. This is not what I get paid to do, I happily pay other people to do that instead but I expect them to understand I'm not an expert in their field.2-Put objecttag to emissive geometry. No need if you select "Auto Detect" in render settings. It's default.
3-Check render buffer and save format. Floatbuffer will make darken output.
4-My all efforts are about to decrease these confusions. You should know the Renderer is workings as state machine.
Why? Cry in private please. Then when you're done find the solution to the problem, as much for you as us. Currently your above solutions don't seem to work too well. Isn't it better to make the solution obvious in the software? Then all your videos and FAQs won't be obsolete in a few releases time.Not resend all data completely. After making lot of video tutorials, manuals and forum support, i think i have a little rights to cry about every very frequent questions.
But it wasn't was it. It was just a link to the FAQ (which is wrong, but that's another issue). And what you're complaining about is the same for ALL sw developers: how to sort the productive feedback from the chaff? That is not the end users problem though, its yours.People don't read well and ask for each simple question before trying a few simple tests. Our answers and investigations on your scenes could be harder than your minor efforts to learn the settings.
sdanaher wrote:Check Geometry in LV Options must have Automatic = on. Then the render settings 'Resend Only updated objects' works. If Automatic = off it doesn't. These two options are in completely different parts of the interface and there's nothing about Automatic mode in the FAQ...
If Automatic mode = off then Resend all scene data also works.
You probably should update the FAQ
